Clear the Address Resolution Protocol (ARP) cache as part of ARP problem resolution procedures.
Switch:1>enable Switch:1#clear ip arp interface gigabithethernet 1/1
The following table defines parameters for the clear ip arp interface command.
Variable |
Value |
<1-4059> |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
